Consider yourself pardoned 9-)centroid467 wrote: ↑Fri Sep 08, 2023 11:08 am If you'll pardon the web store links, we sell the same cable we use in our pre-wired assemblies and connector kits so you can build them to length. Servo and spindle encoders will be fine using the same cable type as long as the conductors physically fit the components.
Encoder cable: https://shopcentroidcnc.com/shop/cnc-ac ... der-cable/
Motor power cable: https://shopcentroidcnc.com/shop/cnc-ac ... wer-cable/
Connector kit: https://shopcentroidcnc.com/shop/cnc-ac ... ector-kit/
EDIT: After taking a quick look at cables I see a connector for THIShttps://photos.app.goo.gl/R6M8C1K9binjiJdy6 Will it work with an Allin1DC? I was planning on offering up for parts.
