Job Timer
NovaStar
CNC Control System Serial Number: 0035FF8A54E0-0610203404
Job Timer
Post by NovaStar »
Hi
So just curious as to why there is no "Time Remaining" displayed for jobs or even "Elapsed Time"
With the CAM software it displays total job time, including machine time, and travels ... So can that info not be passed onto CNC12 and have that time displayed somewhere easily read by the operator?
I just ask because when I post a job and CAM says 3:20:20 for example ... other than keeping time manually I have no idea at around what time that job will end ...
So maybe it could be incorporated at a later stage ??
Re: Job Timer
At the moment you can use M130 to start a external timer App
m130 "C:\MillDemo\FreeCountdownTimerPortable\FreeCountdownTimer.exe"
NovaStar
Re: Job Timer
Post by NovaStar »
Ah cool ...
Better than nothing I guess
Re: Job Timer
You can also use a simple batchfile as a timer .
timer.zip
(236 Bytes) Downloaded 7 times
Sword
Re: Job Timer
Post by Sword »
You can also "Graph" the job and the estimated time is shown when it's finish graphing. I have found it to be very close when running several hour 3D relief files.
Scott
Re: Job Timer
Sword wrote: Tue Feb 28, 2023 11:25 am You can also "Graph" the job and the estimated time is shown when it's finish graphing. I have found it to be very close when running several hour 3D relief files.
Yes, thats the time you need to dial in the countdown timer....
lavrgs
Re: Job Timer
Post by lavrgs »
There is a timer when you "Show GCODE" vs path
Re: Job Timer
This is what I do, once I graph the file I jot down the estimated time and when the job is running the g code screen shows a timer to reference it to.
I agree a countdown timer or estimated time to finish would be a great addition on one or both screens. My fiber laser shows the estimated time and actual time side by side on the screen. Certainly handy for the "longer" cut jobs.
Re: Job Timer
Am I missing something? I thought the elapsed run time of the job had been visible in the status window area, in the upper right of the screen, in every CNC7/CNC10/CNC11/CNC12 version since 1995.
Maybe you are mistaking the runtime graphics display as the only possible job-running display?
Re: Job Timer
cncsnw wrote: Tue Feb 28, 2023 1:38 pm .....
Indeed I have 98% the RTG on :D
