New Build - CNC Plasma Table
- Plasma/Laser Lead
Re: New Build - CNC Plasma Table
Have you tried the contouring smoothing profile?
I’m not aware of that profile
remember smoothing isn't going to make up for big issues like slop or backlash in the machine
smoothing only makes good machines better.
i used smoothing on and off i found good drawings with cleaned up nodes does better then smoothing on in circles
then using heavy node drawing i found smoothing helped a little .
but nothing suits a properly setup rack pinion gear tight motion no slop
exactly.. smoothing does little for a good g code program (good = not a bunch of short ratty vectors) running on a good designed machine.
My Y-axis is tight but I found some shake on the X-axis as the carriage moves along the gantry. Once I get that cleaned up I think it should cut some smooth lines.
