New Build - CNC Plasma Table
Moderators: cnckeith, Joey
Joey
Plasma/Laser Lead
Re: New Build - CNC Plasma Table
Post by Joey »
Have you tried the contouring smoothing profile?
landmark573
Post by landmark573 »
I’m not aware of that profile
Joey wrote: Fri Oct 21, 2022 3:29 pm Have you tried the contouring smoothing profile?
remember smoothing isn't going to make up for big issues like slop or backlash in the machine
smoothing only makes good machines better.
landmark573 wrote: Fri Oct 21, 2022 4:00 pm I’m not aware of that profile
start on page 41
supplement.
jcoldon
Post by jcoldon »
i used smoothing on and off i found good drawings with cleaned up nodes does better then smoothing on in circles
then using heavy node drawing i found smoothing helped a little .
but nothing suits a properly setup rack pinion gear tight motion no slop
jcoldon wrote: Mon Nov 07, 2022 12:28 pm i used smoothing on and off i found good drawings with cleaned up nodes does better then smoothing on in circles
exactly.. smoothing does little for a good g code program (good = not a bunch of short ratty vectors) running on a good designed machine.
landmark573
My Y-axis is tight but I found some shake on the X-axis as the carriage moves along the gantry. Once I get that cleaned up I think it should cut some smooth lines.
