License install issue <resolved>
- CNC Control System Serial Number: 3031
I waited too long to install, but I’ve got my g0704 running happy finally. Went to install my Pro license, got a install okay message, but never changes from free to pro. What am I missing?
- PLC Expert
Re: License install issue
Hello jhelgesen,
This can be caused by the supplied license file becoming corrupt. This can happen for various reasons, saving the file using a Mac or Apple computer and sometimes loading it off of a USB drive are some common causes.
Would encourage you to try and download the file from the email again using maybe a different computer, browser, or email software. If you continue to have the issue, can send an email to diysales@centroidcnc.com with a brand new report (From main CNC 12 screen, Utility (F7) > Create Report (F7)), and can have a new license file generated for you to try as well.
Check out our How to install an Acorn CNC 12 License as well found here. https://centroidcncforum.com/viewtopic.php?f=61&t=3345
When requesting support READ THIS POST first. viewtopic.php?t=1043
Please ALWAYS post a FRESH report. To make a report: https://www.youtube.com/watch?v=A36MSMilMyc.
Centroid PLC Tutorial Videos
I tried a fresh copy and it worked. The previous I had copied to google drive.
Thanks so much.
Now if I could get the dxf import to work. Hit f6 then look and f8 is an empty space. Is there something else to turn on?
Thanks so much.
DXF import is not a supported feature in Acorn
CNC Depot Modular ATC kits
So it does, I thought I heard the opposite, I will bow to the greater knowledge of Centroid staff.
Does this help?
Great video on how it works, thanks.
Also shows me the F8 button that doesn't show up.
I'll post a report this afternoon.
Thanks, JH
Thanks, JH
My understanding is that DXF import works with Mill but not with Lathe.
That is correct. DXF Import is only supported by Mill and Router at this time.
