No motor movement
Kutton
Re: No motor movement
Post by Kutton »
cncman172 wrote: Thu Jan 31, 2019 10:01 pm Do a simple test. Is the stepper locked when powered? If you can spin the motor with drives powered then the driver is not enabled
Russ
Yes the stepper is locked.
Gary Campbell
Post by Gary Campbell »
Kutton wrote: Thu Jan 31, 2019 10:45 pm
Gary Campbell wrote: Thu Jan 31, 2019 9:01 pm A point of clarification: You say: "No green light"
Does this mean there are no status LED's on the drive, or that ones that are there are not lit?
The drive has a green status light but not lit.
Have you tried another drive?
What does the voltage read at the drive? At the power supply?
Any chance the polarity is reversed?
CNC Depot Modular ATC kits
Kutton
Post by Kutton »
Gary Campbell wrote: Thu Jan 31, 2019 11:32 pm
I made share that the controller was connected to computer by pinging controller address.
I thought we were working on x axis, but I try all axis when I try x. All motors are locked when acorn is activated.
Would you know anyone who could give me a wiring diagram from motor drivers to board?
Plasma CNC Controller: Yes
Here is a schematic to try.
I will tell you,
I would start from square one with a Benchtest (NOT IN THE MACHINE)
Fresh install of CNC12 and Acorn BENCHTEST first. Make sure the CNC PC and Acorn are communicating
I would then take ONE stepper driver, One stepper motor, the stepper motor power supply and wire them up to a DB25 breakout board connected to Acorn. MAKE SURE YOU HAVE GONE INTO PARAMETERS and reduced your step rate! If you make a change in Wizard, and save the changes, you HAVE to go back in and change the step rate again. Because the Wizard will overwrite it.
Post pictures of each step. Post a new report.
(Check your Private Messages)
Kutton Acorn.pdf
(498.35 KiB) Downloaded 110 times
Kutton
Post by Kutton »
martyscncgarage wrote: Fri Feb 01, 2019 9:26 am Here is a schematic to try.
I will tell you,
Wiring diagram was the reason I now have motor movement. Thanks Marty. Question I have two steppers running my Y axis. Do I need pro license to get them to move correctly.
Kutton wrote: Fri Feb 01, 2019 1:08 pm
I will tell you,
So you are saying your motors are turning now?
IF so, get X Y Z and SLAVE (Axis 4) all set up the same.
See if they all turn
Yes, for Axis pairing you need to buy the PRO license.
Kutton
Post by Kutton »
martyscncgarage wrote: Fri Feb 01, 2019 1:15 pm
I will tell you,
Where can I find serial number of controller so can purchase pro?
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
Generate a report, it will have the serial number in the report.
Russ
Kutton
Post by Kutton »
cncman172 wrote: Fri Feb 01, 2019 1:31 pm Generate a report, it will have the serial number in the report.
Russ
How to remove program from software?
cncman172
Post by cncman172 »
Not sure I understand your question. Are you asking how to get the report and get the serial number? Or are you asking how to uninstall the CNC12 software from your PC?
Russ
