750W with brake on Z
400W on X and Y
Ready mounted now and power is supplied, no magic smoke, no blown RCD
Next Step is to tune them as fast and stiff as possible with the new A6 software, then to tune the loop with the scales in CNC12 for minimum following error.
The small HTD3-36 wheels are not working with clamping sets with 14 and 19mm servo shafts, so I used Loctite and set screws.
Tomorrow I will solder the DB44 plugs to connect with Acorn Six...
