BORING QUESTION
lavrgs
BORING QUESTION
Post by lavrgs »
i hope I didn't lose your attention already... Is there a way for intercon to do a multi pass boring operation? Or is it an inside turning operation?
Re: BORING QUESTION
Yes, that would be an ID turning operation. The F7/Turn cycle is implicitly ID if you enter a Starting Diameter that is smaller than the Ending Diameter.
Re: BORING QUESTION
The profile cycle also works for boring following the same starting and ending diameter rule that CNCSNW stated. You also need to have the correct Nose Vector set for your tool for either method.
lavrgs
Re: BORING QUESTION
Post by lavrgs »
Thanks for the info on nose vector. The initial pass worked very well. I hadn't tried anything with ID Turning so I'd say it went OK
lavrgs
Re: BORING QUESTION
Post by lavrgs »
I need to understand how Profile will work this making a 1/2 dia hole 1/2 inch deep with a countersink on the bottom using a lathe. I expect to have a 0.236 pilot hole - tap drill for M6 and want to use a Micro100 BBM 60-50-20 boring bar
Re: BORING QUESTION
Profile will start at .236,.05, first move will be a rapid to .5,.05 then feed to .5,-.5, feed to .4,-.5, feed to .236,-.618 then add your finish pass.
Re: BORING QUESTION
This tool with min bore diam 5.4mm is too big to chamfer M6 with 5mm minor ID
lavrgs
Re: BORING QUESTION
Post by lavrgs »
Thanks Uwe
I can make some mods to make it work - may not have to go this deep but I need the screw to seat. I would drill 6mm
Re: BORING QUESTION
You can change the "back-off" distance after a pass using F9 Options in Intercon. This will help with the interference on the backside of the boring bar.
lavrgs
Re: BORING QUESTION
Post by lavrgs »
I will use a 7/16 drill with a 90 degree point to create the countersink and then it's easy...9-) ...right?
