Hello everyone,
I’m reaching out for assistance again. I have connected my PLCEXP1616 I/O board to my AcornSix via H7, with my Plus Limit OK max travel switches connected to it. The Wizard allowed me to add input definitions and change the N/C or N/O LED light indications on the Wizard/1616 I/O screen.
Youtube like here:
However, there are no physical light indications on the PLCEXP1616 I/O board itself, which renders my Plus Limit OK max travel switches and any connections made to the physical board inoperable.
After conducting some research, I came across a discussion that mentioned the PLCEXP1616 I/O board needs to be mapped by making a direct connection to the AcornSix, which I have done in this case. Am I missing something?
Thank you for your help!
Please View my report here.
Please help
PLCEXP 1616 I/O Does not work <Resolved>
- CNC Control System Serial Number: 0074
Re: PLCEXP 1616 I/O Dose not work
please update the video link
and please upload a fresh report.zip
are you observing the PLC1616 inputs on the PLC diagnostic screen? (press Alt i)
No. I am not able to observed the PLC1616 on on the PLC diagnostic seen
This link is a YouTube link that only shows my connection between Acornsix and the PLC1616 boards.
Note that none of the input lights are on. youtube.com/shorts/NlR9ZlQuIdI?si=w5POOkAKiiaNa2M6
i have only 1 input physically connected to the PLC1616 board Fresh Report here:
Re: PLCEXP 1616 I/O Does not work
Parameter 422 must be set to 1 to see inputs 65-80 on the PLC diagnostics (<Alt-I>) screen.
The PLCEXP1616 was detected and working when the report was generated.
The Youtube video is set private so we can not view it.
Thanks a bunch. I am now able to see all inputs on the Plcexp1616.
