hi guys,
trying to turn some radius i realized, that there a visible steps in the surface. i thought, that the servo drives are not well set up, but i optimized all parameters and servos are runny really smoot now with less than 20counts error ( 1/100mm max deviation ) but steps in the radius are still the same. are there other ways to optimize the surface quality ?
Thanks.
turning radius - surface with steps
Re: turning radius - surface with steps
Pls. post used g-code.
- CNC Control System Serial Number: 0008DC111213-1005220061
Sorry, forgot it
- Test_kegel.cnc
- (1021 Bytes) Downloaded 7 times
hi, any idea?
as i saw in the cnc file, the radius is discribed by a G2 Code, so G-Code Smoothing would not help, right ? but i dont think, it is a mechanical issue, because i can turn big chamfers with a perfect surface. only in a radius i have unclean surfaces with steps. i would like to turn wedding rings for me and my future wife, so it would be great to find a solution for it.
thank you in advance
Michael
Michael
I do not think it is a software problem since my lathe is turning without visible steps.
I would try to use sharp inserts and play with U W in G70.
