Random question
setting up an old Sidney lathe to 2-axis CNC with ALLIN1DC Glentek 29inlb motors
When I press Y+/Y- with the jog panel the X servo moves correctly and also in DRO too
when I press X+/X- with the jog panel the Z servo moves correctly and also DRO too
par 300 is set to 3
par 301 is set to 1
par 308 is 1
par 309 is 2
I have X motor connected to out 1 on ALLIN1DC X encoder port 2
I have Z motor connected to out 3 on ALLIN1DC Z encoder port 1
I have tried different mapping and connections with scary outcomes:) (runaway)
I have failed to locate Docs on setting this up. I only can find the Mill set up. Is there a Parms list for lathe?
thanks
ALLIN1DC MAPPING
- CNC Control System Serial Number: 0626181997
ALLIN1DC MAPPING
- report_0008DC111213-0626181997_2023-10-14_10-57-20.zip
- (619.77 KiB) Downloaded 2 times
Re: ALLIN1DC MAPPING
For a lathe, Z is axis #1 and X is axis #2. This info is found in the Configuration section of the Lathe Operator's Manual - https://www.centroidcnc.com/centroid_di ... manual.pdf
Tom thanks for the link!
never would have thought to look for that there.
Karl
Karl
