Mori Seiki BB spindle motor with Centroid
Marik
Post by Marik »
Hey folks,
Would like to retrofit our Mori Seiki BB lathe (similar to SL1) with Centroid. It had a DC spindle motor, so we purchased an AC one Yaskawa EEA-IKM (the one used in SL1). Upon arrival it turns it has a few sets of wiring--two sets of thicker 3 wires, and also it has a multi Pole Resolver TDIA 72B. Could not find any info on either, so the question is it possible to connect this thing to VFD, or does it need a special drive?
Thanks, M
Centroid_Tech
Re: Mori Seiki BB spindle motor with Centroid
Post by Centroid_Tech »
Marik,
Unfortunately, without any information about the VFD that you are using, it is hard to say whether that motor will work. The only information that I could find for that Yaskawa EEA-IKM spindle motor was from Yaskawa's website concerning the Yaskawa VS-626MTII controller https://www.yaskawa.com/pycprd/support/ ... 46/EEA-IKM. If you look at page 14 of the service manual, you will see the cables coming from that motor. The one set of 3 wires is for the U, V, and W phases of the motor. The other set of 3 wires is for a cooling fan that is mounted onto the motor. The last set of cables is for the resolver as well as a thermal overload switch. Unfortunately, I do not know if the Yaskawa VS-626MTII controller is needed in order to run the Yaskawa EEA-IKM spindle motor. As long as your VFD can accept the resolver signals, I would try installing it to see if it will work. You may need to modify some parameters on the VFD in order to get the spindle motor properly tuned.
Bardac makes a pretty good DC motor controller several centroid retrofitters have used them in the case where a machine has a DC motor and is too cost prohibitive to refit with an AC motor.
http://www.bardac.com/shop/productfinder.php
