The PC never flashes when in normal use. I have the man who installed the electrics coming in on Wednesday. so hopefully will have an update then.
Once again thanks for all your help.
CNC10 Version 2.36 on Boss 5 machine
Re: CNC10 Version 2.36 on Boss 5 machine
Here’s the update as promised. All voltage’s checked this morning and all found to be correct. So it was time to take the covers off and check the PC. Opened it up and the fan had fallen off the processor. That would explain why the startup times were not always the same. The plastic bracket had broken. Now fixed and the old machine is back in action.Thank you once again for all your help.
thanks for reporting back
