Encoder Basics
Re: Encoder Basics
Question
Lead, Pitch, TPI all refer to different things but numerically are all equivalent?
*Note in below example TPI is actually 5.08 according to my arithmetic.
5mm Lead = 5mm Pitch = 5 TPI*
Is this correct?
Is this correct?
Re: Encoder Basics
The DMM servo encoder out will work with Acorn.
Clay
Clay
near Winston-Salem, NC
Re: Encoder Basics
Thanks for the reply Clay
Re: Encoder Basics
BigWillie, lead and pitch are the same. TPI is not - it is the inverse of the others. A 0.2" pitch is 1/0.2 = 5 TPI.BigWillieStyle wrote: ↑Fri Jan 05, 2018 1:03 am Question
Is this correct?
Pitch is how far a screw advances in one turn. TPI is turns per inch. So if one turn moves 0.2 inches then 5 turns move one inch. Metric screws are normally specified based on pitches. Imperial screws are classified on turns per inch.
Your example gives the false impression they are equivalent only because 5mm is close to 0.2" but not exactly. 5/25.4 = 0.19685“. 1/0.19685 = 5.08 turns per inch.
Re: Encoder Basics
Remember that the servo motor must drive your spindle at a 1:1 ratio...no belt reduction.
Milton in Collierville, TN
Re: Encoder Basics
Just to be pedantic here:tblough wrote:lead and pitch are the same. ...
- Lead is how far a screw advances in one turn.
- Pitch is the distance between successive thread crests.
- They are the same for a single-start thread (the vast majority of threads you will encounter).
- They are different for multi-start threads: lead = pitch * number of starts.
Re: Encoder Basics
Thanks tb, I appreciate the clarification. Also with regard to encoders, through some additional reading I found a diagram via Dynapar as being a helpful tool for those less familiar, like myself, to delineate the semantics of encoder classification.
http://www.dynapar.com/uploadedFiles/_S ... _29_13.pdf
![Image](https://i.imgur.com/5FCH7MV.jpg)
To the experts, please confirm or correct my assertation with regard to the correct encoder type.
Re: Encoder Basics
Is there any way to use an encoder that does not make the individual A- B- and Z- available but uses a common instead?
This is the specsheet.
https://docs-emea.rs-online.com/webdocs ... e8dd0d.pdf
Re: Encoder Basics
Probably doesnt matter, it has too low res anyways to be any good it seems.
- CNC Control System Serial Number: E8EB11292335-0206180631
Re: Encoder Basics
Chaz, check this out: https://cnc4pc.com/differential-line-driver.html.
