You must post a Report.zip file otherwise will may not respond to the post since we would just be guessing.
The report.zip needs to be attached to your post.. viewtopic.php?f=60&t=943
(Note: A report contains NO personal information, simply the CNC and machine systems parameter settings, faults encountered in a message log, and PLC program being used. this way we can "see" how the CNC system is configured and give you good direction.)
PHOTOS! Post photos of the Machine Tool, the Electrical cabinet and the Operators console. A picture is worth a thousand words holds true for CNC tech support. Even a photo you may think is of no value may lead us to help you with your questions. Post photos here on the forum or use one of the many free photo album sites online and post a link. there is no excuse not to post photos at this day and age when everyone has a phone that takes great photos. If you are going to ask for our time, please spend a few minutes and post images of the system so we can See what you have and give you good advice.
In a rare cases you can't make a report. then we at least require the cnc system serial number and the software version be used to be included with the post.
Centroid kit serial number or system ID (Key-A) number: (i.e. A900123, 0714110123)
Software version: CNC10, CNC11, CNC12 version number can be found on the setup screen or utility screen.
How to Find Control Serial/System ID (Key-A) Number
1- Can be found on the Centroid Unlock sheet that was shipped with the control.
2- On the bottom right-hand side of the CNC11/12 software. 3- Hand written on a sticker on certain components (i.e. MPU11 or Allin1DC) See pictures below, where the sticker is circled in red. Note: for the Allin1DC you will need to remove the gold cover plate.
When posting to the Forum it is imperative that you follow these Posting Guidelines
For a specific, timely answers to any questions on this forum, please take a few minutes to supply us with the information we need to answer your questions.
Include the following with your questions and requests for technical support.
1.) Attach a current REPORT.ZIP file.
The report.zip file contains error message logs, change logs, cnc configuration settings and plc program information. The Centroid CNC controller can be configured in an unlimited number of ways. Without this report.zip file we have no idea how you have your particular system is configured. So, without a FRESH Report.zip file you are asking us to guess at what is going on. Be advised without a Report.zip file, it drags out the time it takes to get to a resolution or no resolution or help at all!
![Smile :-)](./images/smilies/icon_e_smile.gif)
2.) Include a list of the components used in the CNC system with Manuals and Schematics for non Centroid components.
What drives, motors, switches, etc. are being used? INCLUDE attachments or links to the axis drive and vfd manuals! Attach the CNC system schematic being followed (or the one you created yourself) that shows these connections. Add photos of these components and of the CNC installation. Use any one of the free online photo album services and post a comprehensive set of photos documenting your project and include it with your question so we can see what you are doing. Include links or copies of the Spec Sheets, User Manuals of the axis motor drives and spindle motor drive. etc..etc.
3.) What kind of Machine? POST PHOTOS.
We can not stress enough the importance of PHOTOS. PHOTOS are key to us being able to see what you see. Post a description and photos of the machine tool and all its cnc controlled accessories. Picture is worth a thousand words and clears up misunderstanding instantly. The best way is to use a free online photo album service like Google Photos. Upload large high resolution images to the Google Photos, create an Album, put all your photos in one album and click "share" and then "get link" and copy the link it generates and post in your thread, then any one with the link can view the photos. https://youtu.be/yffppUwzKIU
we suggest that all users create an online photo album using any one of the many free photo services like Google photos. This allows all your machine and control photos to be in ONE location and provides a "history" of your machine/project, then you can easily post one link here in the forum and we can see all the photos or just the one you want to show us.. examples... Marty, Kai and I have been using google photo albums for this.. here is an example. https://photos.app.goo.gl/foisQ42QZEbmA4Nv1
4.) Include Screen Shots.
Make them with the built-in free Windows Snipping Tool to show us exactly what you are seeing. Here is a video showing how to do this. https://youtu.be/IfjjCiyAPCo
5.) Include the CNCPC specs, cpu, ram, hd, OS, Touch Screen used and description of any other method of operator control being used.
For ACORN USERS be sure to LOOK at these links below before posting a question.
Acorn Setup Videos https://www.centroidcnc.com/centroid_di ... guide.html
Acorn CNC Videos. viewforum.php?f=63
Acorn Tech Tips, Knowledge Base viewforum.php?f=63
and be sure to use the Search Feature to find posts about the subject your are interested in here is how.
viewtopic.php?f=20&t=205
