Centroid Servo Question
RaptorMachine
CNC Control System Serial Number: many
Post by RaptorMachine »
Hi Guys,
need help with Centroid M4oos System ID # 0316041244 CNC 7 v 8.22
this is a system transplant i purchased used and i am attaching it to a Bridgeport mill
is it ok to use the system without the z axis servo plugged in ?
im not up to the point of having the elrod ball screw system attached, but i do want to move the x and y axis
thanks in advance
Joe
Re: Centroid Servo Question
As long as you don't have bare motor power leads hanging in a pile of chips, it will not do any harm to the control to power up with the Z motor disconnected.
If the control was set up properly, you should have an F5 "2 axis" / "3 axis" key on the F1/Setup screen. If you switch to 2-axis mode, then Z will disappear from the DRO, and the control should be content to run without the Z motor connected.
Did you get the SERVO3IO unit repaired or replaced?
RaptorMachine
Hi, sorry did not see these responses. First, thanks SO MUCH for answering my questions and the question about the z servo being disconnected. I don't think i have the f5 button shown, but I will let you know once i get the machine back together. is that part of the plc programming ? ( I'm attaching pics. the cream colored quill mount {which came with the control} doesn't look like it had an option for the z disconnect feature. the grey one is the elrod mount does {which i intend to install} )
Additionally, once this is repaired and functioning, i intend to upgrade the motherboard so i can install CNC 10. Linux I have another machine with that version installed and would like to keep them uniform. with USB and Network support.
I sent the unit in for repair last week. they should be looking into it now. at first they didn't find any issues with it but i sent the link to the post where you were troubleshooting it and they responded that they would have another look
thanks again !
Joe
RaptorMachine
still awaiting a follow up from the repair dept
hello. Chelsea sent you email, if you didn't get it here is the status of the unit.
Tech Support found no issues with the unit, checked it twice, and put it in long term testing fixture, should be done with "burn in" today.
RaptorMachine
Keith, thanks so much for the follow up.
so if the board is good please advise my next troubleshooting step... please see link to original post.
https://centroidcncforum.com/viewtopic. ... 842#p72842
thanks joe
RaptorMachine
Keith, not sure what magic you guys did, but the Servo board is back in and working THANKS SO MUCH !
Joe
