TT-4 on lathe how to start
- CNC Control System Serial Number: F045DA7F7773-1218181466
Good morning,
I just received my tth-4 for a cnc lathe and I wanted to know how to start with tools number one, step number one is it the part with reference?
if anyone has a how to do it i'm a taker.
and also for a boring bar how do we do it?
thank you very much and sorry for my bad english.
Re: TT-4 on lathe how to start
I bought the lathe TT-4 for my lathe as well. Spend many hours trying to get it working reliably and finally gave up. Interested to see if you have better luck with it.
please post a fresh report.zip so we can see your setup.OptionSR wrote: ↑Mon Jul 10, 2023 10:19 am Good morning,
please post link to photo album so we can see your machine.
hi,
report in attachments and picture here https://optionsr-my.sharepoint.com/:f:/ ... g?e=e7VxsS
thank you
thank you
- report_F045DA7F7773-1218181466_2023-07-10_11-02-08.zip
- (909.68 KiB) Downloaded 1 time
hi Keith,
il already see video.
i'm ok to setup manual tools.
and video with tt-4 you start tools after tools one, how to setup tool one with tt-4 ? the order i need to start.
thank you.
thank you.
using tt-4 is just like manual measure.. same procedure.
use tt to set ref, then go measure the tools same, same
normaly i start whit part, touch z and set my z 0 after i select my x take slim cut mesure and set my x XX but no option for TT for x or z.
if i go to offset page and select tool one in x and select mesure x and select TT the TT start and mesure the size is not correct it's supose show 18.965 but it's show 16.65, i mesure with micrometer 18.965 and i put this number in config, i'm confuse,i start where part ou offset ? to have a good tools one.
ps: tt for lathe, good idee to have option to mesure tt probe as part and only touch Z when you load part.
Good Morning,
I have attached a new documentation for setting your Z ref on the lathe using a TT-4 or TT-2 tool touch-off.
Any feedback on our document is greatly appreciated.
Thanks in advance
Thanks in advance
- Centroid CNC Lathe Z Ref touchoff (1).pdf
- (3.97 MiB) Downloaded 16 times
