Pendent Manual Milling??
so the one major issue im having to deal with converting my manual mill to cnc is losing the ability to do manual machining operations, my design does still allow the use of the handwheels but i am removing my power feed in lieu of the cnc steppers. My question being with the Centriod wireless pendent or maybe a different option will i be able to perform manual milling using my steppers as "power feed" ?
- CNC Control System Serial Number: 0479B7ADF2F3-1127192707
Re: Pendent Manual Milling??
I do that ALL the time. Probably more than CNC control. It works great.
Certainly. It's not the most efficient or safe ( potential to crash), but very doable. Often when I need to trim a plate to rough size, I put it in the vise and then use the machine manually.
Works great to manual control the mill, but for more than 2 moves, I am faster with Intercon...
sure, do the tutorials in the mill manual and watch this:
and here without explaining
By the way, get a WMPG4 from Centroid, works perfectly and reliable
I do use the centroid pendent. It's really great for me.garybergin288 wrote: ↑Tue Jun 13, 2023 1:35 pmdo you use the centroid pendent or are you using a different one?
I use the wireless MPG to clean up stock prior to machining and similar operations all the time. Works great for me.
E415F6F70BC3-0318203049
+1 for me too with Centroid's WMPG4.
Hope this helps
Nigel
Nigel
