Hardinge Accuslide Gang Tool Lathe Acorn Conversion
Re: Hardinge Accuslide Gang Tool Lathe Acorn Conversion
Nice work so far!
sweet! send me the high res original photos and i'll put them on the Centroid website!
slodat
Post by slodat »
I got the existing 1024ppr encoder working with Acorn this evening. Only thing left is get the TT-4 working when it gets here.
This machine is up and running. I have a LOT to learn about gang tool setups. Thankfully we have Suntravel's excellent work as a starting point.
slodat
Post by slodat »
Spent some time sorting out the Hardinge CNC lathe. Turns out the servo tuning was the issue. Got it making a little 1/4-20 bolt kind of part. It's a little slow while I work things out, but it's working reliably!
I need to figure out how the chamfer cycle in intercon works. Kicking my butt currently.
ozarkwoodworker
Post by ozarkwoodworker »
I wish I would have seen your thread sooner. I also converted a Hardinge Accuslide lathe. Mine was a DV59, but it came with an enclosure. It was in pretty rough shape, but I got it so cheap, I didn't mind. I replaced all the motors and linear rails. I also made it a direct drive, because Accuslide left the mechanical variable speed setup in there. I also bought a way cover for some random CNC mill that just was the right size for the front of the carriage. I tried to keep it all in as small of a footprint as possible. But it's been a nice machine.
slodat
Post by slodat »
Machine looks great! I like the enclosure.
slodat
Post by slodat »
I have the Accuslide running OP2 on production parts I make for my business. OP1 is on a 1986 Okuma LB12 two axis lathe with the original control. It’s a great running old machine. OP2 is this simple threading operation. Perfect for the Accuslide. I wish I could figure out edge break chamfers in Intercon. I’ve asked several times and it is not as easy or conversational as the other operations in Intercon. I do it with a file and that’s working alright.
The timelapse is deceiving. It's a six minute cycle. The nature of the setup, stickout, tool, etc mean I take 0.015 depth of cut at 8in/min. I'll take reliable and slower over fast and problematic every single time.
Parts are looking good as well. They get tumbled, so it's not a big deal to have a small surface finish anomaly.
This is the current tool setup. It may be in this configuration for a very long time now that it's making money!
Nice work!
lavrgs
Post by lavrgs »
Have you considered a direct message to cnckeith for the chamfering question?
slodat
Post by slodat »
My plan is to purchase an hour of support time and sort through what I need then. Been busy. Will do when schedule allows.
