I have a new installation on a fairly new CNC Router. I had been running Mach4 and finally got frustrated with the jumps while cutting parts. Please note this is a fairly new machine, that started as an Open Builds OX. I started some upgrades and eventually built a new CNC. It is using 600oz. inch NEMA 23 steppers from Corvetteguy on YouTube. Noisey but they are good. Ball Screw transmission with HiWinn linear rail. My motor drive is a Gecko G540 that use to connect to a Win7 32-bit computer. the Y axis has 2 steppers so the A axis is always paired with Y.
I am using an older Dell I5 desktop computer that came off lease and was upgraded from Windows 7 to Windows 10.
I had installed and partially configured Acorn 12CNC but never connected to the CNC as I had to make a larger enclosure for the controls with the addition of the Acorn board. I had made some senior moments setting up the computer (Auto Windows update, and configuring the ethernet port) installing the AcornCNC software, and decided that if I haven't connected it to the CNC to start from scratch. I uninstalled and deleted the CNCM directory, restarted the computer and installed Centroid CNC12 4.14
I noticed that while the install went fine, I do not recall that the Acorn board bios was updated.
Is there a way to tell if I have the correct bios version?
I am now into setting the motors and discovered that specific event un-pair the Y axis.
I will be going through my setup and configuration again this weekend, but I am noticing some very erratic behavior.
While setting up the overall turns ratio, I found that every time I went enter MDI code that my system un-paired the Y axis.
I have included the log file that is shown on the screen. There is an error
I assume the correct sequence is to configure the motors in the wizard, save the settings, then turn off the Acorn board, and turn off the Centroid software, then restart the computer, the Acorn board, and finally Centroid CNC.
I also noticed that after starting Centroid CNC, clicking 'Reset' and then Cycle Start that X & Y are not zeroed. I am homing manually, as I am still not comfortable with movement generated by Centroid.
Although I am extremely concerned about unpairing an axis, i.e. that should never happen as that is a hardware configuration, I am hopeful I can eventually get there.
report_3403DE6064C2-0325191813_2019-05-11_15-28-42.zip
