Tool touch off and probe help needed
Hey guys, so I am not sure why I can't seem to get this to work how I want it to, but I feel like someone here might be able to help me.
So I would like to be able to probe my top Z zero for my G54 work coordinate and have it so all of my tools that I touch off on my fixed tool touch off are set to that Z zero point and I can't seem to get the settings right or something just isn't working properly. Does anyone have the proper settings in the wizard or parameters that may be messing me up here?
I appreciate any and all help a ton.
-Greg
-Greg
Re: Tool touch off and probe help needed
Please tell us what is happening and why it's not working? What macro are you using? Please post a current report from the machine and/or the PDF
with all your current wizard settings. We can't really help unless we know how you are setup and what is or isn't happening.
Open the wizard press CTRL P and save the pdf to the desktop and then post it and/or a report here.
There are several macros on the forum to do exactly what you want. This is an old topic with a lot of info.
https://centroidcncforum.com/viewtopic. ... &start=160
I will post the report after work and take a look at that post thank you.
Ok so here is my report. Can anyone fix it up for me to do the above? I will pay anyone if they know how, lol.
- report_20D7787C5DA2-0724237403_2024-04-30_15-19-43.zip
- (1006.45 KiB) Downloaded 4 times
how about some photos of your machine/setups, wiring etc.. what kind of probe? is it NC or NO? what kind of machine is this? knee mill? bed mill? make a photos album with lots of photos. post link here.
and initially its easier for us to see your Wizard settings sometimes so open the wizard and press CTRL P and post the PDF it generates here.
there is a selection in the Wizard TT menu that tells CNC12 that you want to use the Probe as a reference tool.
A side note here, looking at your report, I'm not sure how you came up with your steps per revolution. You have them set to 25,400 on the X and Y and 40,650 on the Z axis. Can you share how you got those numbers as those are incorrect settings for Acorn and your drives.
What drives are you using?
And as I mentioned before and Keith also stated, open the wizard and press CTRL P and post that PDF here.
You have other issues to fix first before you go further.
What is the macro number for your tool touch off macro?
Ok so i have a pm 728vt Mill.
-X and Y axis have STEPPERONLINE High Torque Nema 23 CNC Stepper Motor 114mm 425oz.in/3Nm CNC Mill Lathe Router and TB6600 Driver ST4045
Here:
https://amzn.to/4b8Vszo
and
https://amzn.to/4dlTe1p
-Z axis has a Nema 34 Stepper Motor 6A 12Nm (1700 oz-in) 156mm Length for CNC Router Mill Lathe with STEPPERONLINE CNC Digital Stepper Motor Driver 2.4-7.2A 18-80VAC or 36-110VDC for Nema 34 and 42 Motor DM860T
Here:
https://amzn.to/4aYWHRS
and
https://amzn.to/4aUAEfh
-Probe is a PGFUN CNC 3D Touch Probe Upgraded XYZ Axis Anti-roll Edge Finder Waterproof 3 Coordinate Measuring Sensor Kit with 6mm Shank & 6.5 Ft Cable, Compatible with Mach3 (Edge Finder-NO)
Here: https://amzn.to/3JFzmIX
-Tool Touch off is a NC located
Here: https://amzn.to/3UGzUVx
Pictures(not very good, but) here's some:
Here:
and
Here:
and
I will do the PDF after dinner just give me about an hour.
I cant figure out how to do the pdf, it wont preview it at all for some reason. what else can I do?
